How to set Honeywell Pro TH411Od with Hydronic Heating Boiler?
I want to make sure I set this up correctly. I have an independent boiler for hydronic heating (baseboards) and central AC.
1) System Type (options are 0 and 1)
0= Gas, oil or electric heat with air conditioning
1= heat pump
2) Cycle Rate
5= For gas or oil furnaces of less than 90% efficiency
1= For steam or gravity systems
3= For hot water systems & furnaces of over 90% efficiency
9= For electric furnaces
I figure System Type is 0 and cycle rate 5. I have Adaptive Intelligent Recover off. Does this sound correct?
1= heat pump
2) Cycle Rate
Those settings should work ok.
Adaptive recovery is how the thermostat responds at the change of a program. If you have the heat set to go from 65 during the night to 70 at 8:00am it will start bringing the heat up gradually so that by 8:00am it's at temperature rather than raising the temperature right at 8:00am.
