Frost on tankless propane water heater
Quiet Side DPW120A tankless water heater
There is frost on top right corner of the unit at the combustion are intake. Is that normal.? It's below 0 out if that matters. I have a HVAC coming tomorrow to descale due to error code. I just want to have other opinions on if that is normal or not when I ask about it. They just came last week to fix it from another error code.. And found that the dip switch was never changed to propane after it was converted. Now I had error code A5 and the Quiet side tech said it needs descaling. The heat exchanger had to be cleaned and now every time it sounds different to me I go in room to see if there is a code on. So I see frost on it while its running and want to know if its normal..
I agree with Troop, I have a small draft on the front door sash, if I don't cover it with a towel I get a line of frost inside where it bleeds into the house. Yes, it's that cold this year!!!
