air quality
air quality
My home was originally built in 1880 and when I bought it in 2002 I had an addition put on that included my master bedroom on the second floor. The home is heated by hot water baseboard. In the winter when the heat is on it is difficult for me to sleep in the master bedroom because I get very dry and my nose gets clogged and I have to sleep in the bedroom in the original part of house where it is fine. At almost the very moment that I go to the older room I clear up. I'm not sure why there is a difference but there is. There seems to be a humidification problem and I don't know what to do about it. Does anyone have any ideas how I can get that air better? Thanks.
Rich
Rich
Air leakage brings in dry outside air with no moisture. Your new bedroom is probably better insulated and has less air infiltration from outside then the old room.
Why not try a cool mist humidifier in the master bedroom ?
Last edited by PJmax; 03-14-15 at 10:41 AM. Reason: Thanks Droo....corrected mistake
One of the difficulties with baseboard hot water is no air circulation, thus humidity levels in one area can be different from another.
I would start with a couple of inexpensive meters to keep track of relative humidity and temperature in the different rooms. I'll attach a calculator that can be used to compare RH readings at different temperatures. You wouldn't want to chase humidity issues if it is an allergy problem.
Bud
Temperature, Dewpoint, and Relative Humidity Calculator
Bud
Vermont adopted a state-wide Energy Building Code in 1995 which required new residential buildings and any new additions of over 499 SF to be so air tight and thoroughly insulated that it created similar breathing problems shortly thereafter.
They then had to modify the Code in 2004 to implement a Ventilation component to make these areas less unhealthy for the occupants . . . . with some form of forced air exchange.
It will be decades before we fully know the ramifications of that original mistake.
It's another aspect of the Law of Unintended Consequences.
PJmax, the opposite happens in the winter. Air leakage brings dry air into the house.
It has rained a half-inch during the last ten hours and the current outside temperature is 51 degrees. My indoor RH is definitely going up.
RELATIVE humidity is based on air temperature. Any time air is heated without adding humidity during the fact, the RELATIVE humidity DROPS like a stone.
Winter outdoor air is generally dry to start with, heat it up and it gets even dryer.
If I don't put about 5 gallons a day into my home's air the RH runs about 20% or so. I think the Sahara is about 17%. Humans are comfortable at around 40-50 or there about, but running RH that high in the winter and you risk mold issues where the water condenses on cooler surfaces, exterior walls, behind and under furniture, window glass, inside ceiling light fixtures, etc...
Don't rule out an alergy to a specific material in the new bedroom
Anyone remember the Chinese drywall fiasco of several years back?
http://en.wikipedia.org/wiki/Chinese_drywall
