Argo six zone control- switching relay buzzing
Old 05-26-15, 06:29 PM
R
Smile Argo six zone control- switching relay buzzing
We have an Argo Six Zone Control Switching Relay [ARM-6P] that is buzzing like crazy.
Argo Six Zone Control Switching Relay [ARM-6P]: Electronic Relays: Amazon.com: Industrial & Scientific
It used to just buzz for a little while then stop, now it buzzes a LOT especially before the furnace kicks on. The red 'priority on' light comes on when it buzzes. I have tried removing one by one the 6 little circuit plug-ins, but that didn't matter. We replaced the main relay but that didn't help either. Is the entire switching relay in need of replacement? Thanks.
Old 05-28-15, 07:25 PM
Received 1,476 Votes on 1,364 Posts
Welcome to the forums.
We keep a topic in a single thread so this is the only thread running right now.
I didn't have an exact answer for you. I looked at the schematic for that unit and it looks like the relays are run on DC voltage..... can you confirm that by looking on the relay ?
If the relays are actually run on DC voltage then you have a board problem.... not a relay problem.
The forum pro, NJT, may have other ideas.
Old 05-29-15, 03:02 PM
NJT's Avatar
NJT
NJT is offline
Received 4 Votes on 3 Posts
You have priority switched "ON" and are using the priority input ?
I believe that zone 1 is the priority zone, do you have an indirect water heater on that zone?
Old 06-05-15, 08:14 AM
ReekoS
I am assuming that this switching relay commands the furnace to "ON" when a zone demands heat?
If so it might not be your relay, but rather a defective microswitch contact in one or more zone valves.
If so this is easy to troubleshoot.
