Draining boiler
Received 0 Votes
Draining boiler
At a home inspection, inspector said you have to take water off a boiler weekly during heating system. It is a newer boiler,2012, well mclein steam radiators. Never had a system like this and did know the accuracy. Is it necessary to purge system during heating season?
Are you sure this is a steam system and not a hot-water boiler? If it doesn't have a gauge glass to show water level, it must be a hot-water boiler. If it has a circulator pump, it must be a hot-water boiler.
A steam boiler is usually provided with piping for blowing down the boiler to remove sediment on a routine basis. A hot-water boiler will have a drain valve, but it should not be routinely drained except when necessary for maintenance of a component, such as a circulating pump.
Received 0 Votes
Draining boiler
Thought I saw a glass gauge in back of boiler. Home inspector pointed to boiler valve on where to drain off water weekly. Just never heard this info before.
Before you do any draining...
Please go to the boiler and look at the data plate and tell us the make and model of the boiler.
If this IS a steam system, there is a bit of information you need to know.
