Super Hot S135 boiler Circulating pump won't turn off.
Old 11-25-15, 03:16 AM
Angry Super Hot S135 boiler Circulating pump won't turn off.
Hi I have a 30 year old Allied Super Hot S135 4 zone boiler that was completely rebuilt last winter because the heat exchange core fins were plugged with carbon and the flames come out the front looking for air. When the flame came out it melted gas valve and everything.
The boiler itself was fine no leaks just some discoloration from the flames. So it was taken complete apart cleaned installed new heat and flame resistant batten and reassembled.
The 2 aqua-stats where replace the pressure and temperature gauge was replaced and the relay was replaced along with new wiring and new burners installed even the expansion tank was replaced. The only thing that wasn't replaced was the circulating pump.
Now the boiler will fire up when the temp drops down to approx 120 and then turns off at approx 150 but the pump never turns off.
Does anyone have any ideas about this type of problem.
Thanks for any help
Old 11-25-15, 05:55 AM
Will have to DL the wiring diagram, but it sounds like the aquastat that controls the circ pump is either done or not set right
Old 11-25-15, 11:46 AM
The L4006A one is set to 140 and the L4006E the one with the reset button is set to 180
Old 11-25-15, 05:33 PM
I could not readily find the I&O manual.
if you have it scan and post the wiring diagram
Old 11-25-15, 07:32 PM
I have never tried this before so I hope it works. I uploaded what I have to this link.
https://mega.nz/#!MYxTzIga!swI50q9Vo...l0UKabOx1ImEJA
Just copy it to your browser address line if it doesn't go when you click on it. PDF file.
Thanks.
And any idea what the aquastats should be set at?
Old 11-25-15, 08:17 PM
it's asking me for a dycrption key.
The settings on the aquastats are good
Old 11-25-15, 11:35 PM
Old 11-26-15, 05:57 AM
Sorry, still not working for me !
Old 11-26-15, 06:22 PM
Thanks for trying TO
Through the process of elimination I found a faulty wire in the wall to one of the 4 thermostats it looks like. I will keep you up dated. Thanks Again for trying
Old 11-26-15, 06:37 PM
Received 419 Votes on 392 Posts
In case you need to still post a picture. Using a remote host will allow for a larger file size. My personal favorite is photobucket which is also a free site. It's explained in my link.
http://www.doityourself.com/forum/el...-pictures.html
