Relay Wiring Honeywell R845A
Old 11-29-15, 08:31 AM
The relay (Honeywell R849 1030) was not activating the circulator pump. So, before I was going to change the relay I jumped the T-T wires and the relay worked. I am assuming that the relay is functioning and that the problem is with the thermostat or the thermostats wires.
Also, the relays that were activated showed 0 volts across the T-T terminals and that one that is not activating is showing 24 volts across. Is that the way it should be?
Old 11-29-15, 10:25 AM
Received 520 Votes on 490 Posts
Welcome to the forums.
Is that a mis-type ??
What relays ?
we can't see what you have there. If you don't describe it or post pictures of it....we're in the dark.
Are you talking about zone valves ?
