Honeywell Aquastat L8148E voltage
Old 03-05-16, 03:08 PM
My L8148E Aquastat seams to be working fine but I'm not getting 24 volts between tv and t . I'm trying to install a nest thermostat and it needs 24 Volts.
Old 03-05-16, 07:09 PM
Received 479 Votes on 449 Posts
Welcome to the forums.
You will need a third wire between the nest and the L8184E for a C connection.
Old 03-06-16, 09:22 AM
Received 1 Vote on 1 Post
hi Clay Ė
Are you sure the 8148E is good? It seems to me if you donít get 24 volts across T and TV doesnít that indicate that the 8148E is bad? But maybe I donít understand.
Old 03-06-16, 09:59 AM
Thanks. ALLs good. My third wire was cut. not needed with old Thermostat. Nest is working fine so far.
Thanks again Clay
