circulation problem
Old 03-07-16, 09:36 AM
circulation problem
I have a Hydronic heating system installed in my home, I have added a extra 3/4" line to the system as this is now the longest line on the system I am having problems of it recovering fast enough from on/off. my idea is to install a Booster pump on this line .
Can anyone advice a small pump that can be installed vertical , the system runs on three Armstrong astro 50 inline but I only use two as the third one does not make any differance , I was thinking of maybe using this one if it could be used in a vertical position, though the least work is to install a new pump. Thanks. BL.
Old 03-07-16, 06:13 PM
P
Temporarily Suspended
Is it possible that a 1/2" pipe would have given you more pressure, instead of more volume?
Old 03-08-16, 06:06 PM
rbeck's Avatar
Received 15 Votes on 11 Posts
How many fet of element is on that line, not cover but element? How long is the run from the boiler through the loop and back to the boiler which is total lineal feet of pipe including the element.
