Sealing a house radiator at the nut
Old 12-12-16, 03:56 PM
Despite a fairly tight turn with the wrench, when the heater system runs, there is a slow drip from the nut. I would like to simply seal it with something anaerobic or some sort of epoxy, and one that can withstand hot steam. That's hot.
There are probably dozens of products, I just need one. I don't know if Permatex has something that can withstand the temperature.
I don't want liquid teflon products - I don't think they are the right product.
I've heard of Permatex's, Loctite's, Sydglass, LacoLoc, Vibratite, Basswhite, ..., perhaps one of these companies has something. I would favor a high temperature sealant that hardens like a resin. Do the automotive stores have something?
Naturally, I would prefer something that has low back-wash into the plumbing but I'm not that worried, as long as it dries, it should be ok.
It's ok to recommend more than one product - I assume this is a fairly common problem.
I could turn the nut more and more but I am just being careful. Perhaps that's all it needs, perhaps not.
I want a solution that's not so time-consuming waiting to see if it leaks.
Old 12-12-16, 04:04 PM
Received 255 Votes on 240 Posts
There is no miracle sealant like in "as seen on TV".
You can't seal the nut...... just the ground mating surface.
A little bit of plumbers pipe dope on the mating surface.
Old 12-12-16, 04:16 PM
I don't know of any products called "plumber's pipe dope". Do hardware stores sell this?
Old 12-12-16, 04:33 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Pipe dope is used by plumbers therefore it is plumber's pipe dope. It's as common as dirt. https://en.wikipedia.org/wiki/Pipe_dope
Old 12-12-16, 05:02 PM
Received 5 Votes on 5 Posts
Everybody, including plumbers, call it "pipe dope," but it's not called that on the bottle. Any hardware store worth its salt should know what you mean by "pipe dope."
