Water heater 10 gallons120/277
Old 12-29-16, 02:25 PM
I connected today 3 water heater 10 gallons. 120 v can't get the hot water . Tried temp .change nothing
I tried conecting 220v and nothing can someone explain
Old 12-29-16, 02:33 PM
Received 120 Votes on 107 Posts
Welcome to the forums!
Your post isn't very clear did you hook up 3 separate water heaters or 3 together?
Have you verified you have current at the element?
Old 12-29-16, 02:43 PM
I conected them separately . I do have current flowing. Temp set at max and nothing
Old 12-29-16, 04:02 PM
Handyone's Avatar
Does your water heater have a built-in switch?
If it does, that leans towards 120V.
You should post pictures of the cable you are using and the breakers.
This could be dangerous.
A typical 120V heater requires a dedicated 20amp circuit. You probably need to run 3 separate circuits to each location.
Old 12-29-16, 04:30 PM
I have no switch by the connection . I used 12/3 wire. 20 amp braker each.
Could it be that the termostat is not working?
Old 12-29-16, 05:02 PM
Received 341 Votes on 319 Posts
I connected them separately . I do have current flowing. Temp set at max and nothing
If you had current flowing you'd have heat.
You connected three water heaters to three 20A circuit breakers and not one of them heats the water ?
You said 120/277...... water heaters do NOT work that way. It's either a 120v or a 208/240/277v water heater.
Old 12-29-16, 05:35 PM
Handyone's Avatar
Hey Pete!
I deleted my post because the diagram I attached doesn't make complete sense to me, but it might help.
Old 12-29-16, 05:50 PM
Thanks for replying. That's exactly what my heaters show. Could it be that thermostat or the hi temp switch r faulty? I also have a reset button but when I press it it doesn't doo nothing, like gfi make click sound
Old 12-29-16, 05:53 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I used 12/3 wire
Should have been 12-2, black and white +ground.
You should have tested for voltage with a multimeter or test light. (A non contact tester won't work for testing.)
Old 12-29-16, 06:02 PM
Tested it with probes multimeter. It shows 120 v . I I set temp 150 witch is max and nothing
Old 12-29-16, 06:06 PM
Brian....you show two diagrams..... other than the color of the wires..... they are basically identical. We know that putting 240v on a 120v element will burn it up.... while putting 120v on a 240v element will yield next to nothing.
So the heater voltage needs to be determined to effectively connect it.
The box would not say on it 120v/277v. It would have a voltage selected.
Old 12-29-16, 06:36 PM
Ok I see what u saying . The reasone why I'm confused is . On the when I look up the instructions it says. I quote "Standard single element 120v and 277 v ", and the diagram that is posted
Old 12-29-16, 06:42 PM
The diagram is the same but the element is not.
The voltage is usually stamped on the nut part of the element.
Old 12-29-16, 06:48 PM
Thank u for clearing that . Now I connected 120 . I get 120 in the unit, temp is set to 150 f . No hot water runing
Old 12-29-16, 07:12 PM
ray2047's Avatar
Disconnect the wires from the element and check the resistance. If it is open you brobably burned it up when you,
Old 12-29-16, 07:23 PM
Handyone's Avatar
I somehow knew that you could answer that Pete.
WATER HEATERS EQUIPPED FOR ONE VOLTAGE ONLY:
This water heater is equipped for one type voltage only.
Check the rating plate near the bottom access panel for
the correct voltage. DO NOT use this water heater with
any voltage other than the one shown on the model rating
plate. Failure to use the correct voltage can cause problems
which can result in death , serious bodily injury , or
property damage
