can you identify this stuff???
Old 01-01-17, 09:39 PM
This stuff was found in 4 rooftop heat exchangers, Carriers 14 years old, with a history of sooting up. These are converted to LP units. No exhaust nearby that we know of save maybe a small farm. all 4 within 50 to 80 feet of each other....Ill post picsName:  2015-04-21 09.57.37.jpg
Size:  41.1 KB[ATTACH=CONFIG]75164 OEM says its not part of the unit. its very hard, almost metalic. This is an elementary school.
Old 01-02-17, 05:37 AM
It looks like an abandoned wasp or hornet's nest.
Old 01-02-17, 06:52 PM
Wasp nest?
That would burn up during the first start up I would think..
Old 01-02-17, 09:18 PM
Old 01-03-17, 02:53 AM
Nest
I can't really argue that, that is about what it mostly resembles in shape. What threw me off on that was its metallic and sharp feel.
Old 01-03-17, 08:16 AM
Received 19 Votes on 15 Posts
Looks and sounds to me more like a piece of coral. Something that would be left behind in a wet environment. Was it found under water or in the upper part of the unit? Are the units located in an area where the water or air would carry some small sea creature?
Old 01-03-17, 08:32 AM
But the wasps and insects are much better craftsman than that. Notice in the nest picture how perfectly regular in shape each compartment is. No self-respecting wasps would do that sloppy work depicted in post #1.
I have no expertise at all on this subject but I found this link which at least says that there is such a thing as Crystalline Deposits in Heat Exchangers. That’s what it looks like to me anyway, some kind of crystal formation.
https://sundoc.bibliothek.uni-halle..../04H181/t4.pdf
just saw 2john's post
Old 01-03-17, 09:02 AM
LOL @ self respecting wasps & sloppy work! I wonder if OSHA laws apply.
Old 01-03-17, 09:52 AM
LOL - Yea - you wonder. OSHA probably has a thousand pages on it, LOL.
Old 01-03-17, 12:20 PM
Grady's Avatar
Have you tried dissolving some of it in vinegar or hot water? If it dissolves or fizzes in vinegar, chances are it's calcium based.
What are the BTU & efficiency ratings on the units?
Old 01-04-17, 04:11 AM
The rock
Spoke with the mechanic last night that found the stuff and he insists it's not a bees nest but rather some kid of carbonized crystaled form from unburned fuel. It was in all 4 rooftops and up deep inside ( not what bees do). Bees, for the most part, tend to like the hottest piece of sheet metal on the unit, usually the disconnect. Why, That I couldn't tell you, but they nest in lower roofs more than taller roofs. The mechanic also said it wasn't that strong, and fell apart quite easily, and that I have selective recall....(. Part of getting older). In the mean time, next time I go there, if for the same thing, I'll check with the maintenance guy, he kept a chunk, Thanks for the help!
Old 01-04-17, 07:29 AM
I value the mechanics opinion. However, why don't you show it to a bee keeper or someone who knows about bees & wasps?
Old 01-04-17, 08:11 AM
Reminds me of the metallic sponge inside a Catalytic Converter; but I suspect this is intended to condense moisture and capture it to be funneled away BEFORE it becomes ice and does more damage up on the roof.
