Does oil burner actually use the chimney?
Old 06-05-17, 08:46 PM
B
Hi.
The house I moved into (1971 built) a couple years back has an oil burner for heat and hot water and of course is attached to a chimney. When we moved in the guy before had a little wood stove in the basement also attached to the chimney. We took it out cause I guess they said it wasn't legal or something.
Anyways, I'm wondering - Does the oil burner actually use the chimney?
Old 06-05-17, 09:00 PM
Received 106 Votes on 93 Posts
With that little info and no pictures not sure how anyone would know.
That oil burner has to exhaust some place.
Far more likely that wood stove should have had it's own chimney.
Old 06-05-17, 09:43 PM
Received 1,599 Votes on 1,473 Posts
Yes..... the oil burner absolutely needs the chimney.
Old 06-06-17, 03:29 AM
Received 426 Votes on 381 Posts
While there may only be 1 chimney, it should have separate flues for each device that is attached to it. The furnace and former wood stove should each have their own flue, the same is true for a fireplace if you have one.
Old 06-06-17, 01:34 PM
B
Thanks all!
I gotta go up on the roof and measure for a chimney cap. We had a dead bird that I pulled out of the bottom where you clean the chimney!
