Another Riello 40 F5 Leak
Old 02-15-18, 05:39 PM
I was told my hydraulic jack was leaking. Replaced that today and my leak is still here.
Link below is a video of the leak, may want to turn the volume down a little before playing. It Looks like the leak is coming from the top of the air intake housing? But I can't find anything to confirm others with a similar issue, or a replaceable part to fix this.
https://youtu.be/agwCB6V7BAo
Second video you can clearly see the gurgling oil.
https://youtu.be/bsSbI-TpVcs
Thanks in advance for the help.
Old 02-17-18, 09:21 AM
Received 1 Vote on 1 Post
Could be the oil pump shaft seal.
Sid
Old 02-17-18, 02:30 PM
Or the line to the hydraulic jack line, or the line to the nozzle.
Sid
Old 02-25-18, 10:21 AM
Grady's Avatar
Received 13 Votes on 11 Posts
The fact oil is coming out the seam in the fan housing & the sound, leads me to believe you not only have an oil leak but the motor bearings are on their way out.
Old 03-08-18, 03:39 PM
Is there an advantage to a hydraulic vent? I bought a used F4 burner assembly for parts and that one has a hydraulic vs mine that has a static vent.
thanks.
Old 03-08-18, 04:54 PM
Grady's Avatar
Yours has a hydraulic jack. I've never heard of an F4.
Old 03-11-18, 06:45 PM
Sorry - typo, meant F5
Mine is static, just a fixed open window on the side of the intake.
Old 03-12-18, 10:25 PM
Grady's Avatar
In theory shutting the damper stops air flow thru the burner & boiler during the off ciycle & in doing so reduces heat loss up the chimney. In reality I question how much. Unless you have a really tall chimney, I would not install the damper.
