White rodgers zone valve to digital honeywell tstat help.
Old 03-06-18, 05:10 PM
The valves a 3 wire zone. With terminals C, 4, and 5 going to tstat. Not sure which should connect to which. Tstat has usual lettered terminals O, B, R, W ETC. It is compatible with the heat system as per manufacturer specs. HELP
Old 03-06-18, 06:16 PM
Received 380 Votes on 357 Posts
Welcome to the forums.
I need the model number of that zone valve.
Not sure if that valve needs an intermediate controller.
Is this a new installation ?
Are there other of the same type valves in use there ?
Is this what you have.... emerson climate/Valves/Documents/Cat_06_pg0298.pdf
