Apartment too hot!
Apartment too hot!
Hello everyone,
I live in an apartment building on the top floor (5th) and they turned on the heat for the year the other day. My apartment feels like summer in Vegas... even with all the windows open!
I have a baseboard heater running through my main room and bedroom as well as one in the bathroom. I read that if they're water based, I can cover the fins with heavy duty aluminum foil and that should do it.
My landlord is not the most responsive. How can I tell if this is water or electric based? I have a few photos of the knobs, which lead me to believe it's water.
Images
EDIT It doesnt seem to want to link to a photo
Thanks for any advice!
Images
Welcome to the forums.
If it's a "building based" system..... it will be hot water.
How-to-insert-pictures
If it doesn't have a thermostat like Dane posted.... you could turn one of those yellow handles off and stop/reduce the flow of hot water.
Either one.
Just remember that during the winter.... some water must be allowed to flow thru those pipes to prevent freezing where the pipes pass thru cold locations.
You'll soon develop a knack for moving the yellow handle the perfect amount to get the heat you want. Off and on are easy but getting the right amount might take some fine movements of the lever.
I have fond memories of an apartment where I had the magic touch. It took me a couple days to learn just how much to move the lever but I became quite adept at getting the apartment to the desired temperature. There was no thermostat so it wasn't automatic but it soon was second nature to just titch the valve as needed without thinking about it.
Depending on the type of building and boiler controls the aluminum foil trick would be my choice and has been for many years. Also, the baseboard units should have a moveable damper that can be opened or closed that will allow at least some adjustment. If your baseboards do not have the dampers installed I would ask the building maintenance if they were removed and if they were could they re-install them. A picture of the whole baseboards, especially the top part would help.
When the opportunity presents itself, move to someplace that you have control of the heat. I doubt that you will ever be fully happy with your present situation, but the aluminum foil idea may alleviate your misery.
Don't uninstall anything. You may cover the radiators with anything you want to. There is no danger of fire with a water or steam based system.
If there is a really cold snap outside then uncover the radiators and enjoy the heat.
