System 2000 - Wireless Thermostat - C Wire
Old 11-10-18, 09:15 AM
N
I have a System 2000 EK1 with the older "classic" controller. 5 zones plus hot water. Digital thermostats heat-only, but it's all 2-wire. All the whites are bundled on terminal A2 and the reds are on the Tx's. See photo. Because of the difficulty fishing wires to move one particular thermostat, I'd like to replace it with either the Honeywell YTH6320R1001 or the Braeburn 7500 wireless kits. In looking at the specs for them (see photos), I think the most basic wiring will require a red, white, and C common to the control module. Any advice on how to do this with my setup? Thanks.
Old 11-11-18, 02:38 PM
Received 1,480 Votes on 1,368 Posts
Welcome to the forums.
Really...... all this work instead of moving the wiring.
The diagram shows the connections to the EIM. You will need to disconnect the current wire from the proper T terminal and connect the white from the EIM in its place.
Old 11-11-18, 07:06 PM
N
Thanks for responding. I appreciate it. No, I really have a good reason for not moving the existing thermostat wiring. This is worth it believe me. I think the difference in the diagram you attached is that the transformer on my system isn’t wired to A1 and A2. It goes instead White to A2 and Black to the “B” terminal below A2.
Old 11-11-18, 07:18 PM
I don't know what was done there. I went strictly by the install manual. Whatever common terminal is used for one half of all the stats must be the red. The white goes to the zone. The C wire is the opposite transformer lead.
