Gurgling sound forced hot water
Old 12-22-18, 07:42 AM
K
Received 3 Votes on 3 Posts
We have a forced hot water system. I can hear a lot of flowing water sound. I know there is air in the system and I somehow need to fill those air pockets with water. The question is, how ?
i am attaching some pictures of the system if someone can point which valve(s) I need to open or close
Old 12-22-18, 08:03 AM
Tolyn Ironhand's Avatar
Received 93 Votes on 83 Posts
You need to bleed the air out of the system. There should be bleeder valves on your radiators.
Old 12-25-18, 07:23 AM
K
Thanks much. Bleeded through the valve in baseboard. First air, then stuttered water and finally normal flow
However, I did it only in the baseboard where I was getting the noise
The sound reduced for a few days but back again Tried bleeding again, and some stuttered water came out. Looks like there are still air.
Do I need to check/do anything else ?
Old 12-25-18, 09:04 AM
You need to bleed all radiators to get all the air out. You might also need to bleed at the boiler.
Old 12-25-18, 04:47 PM
K
Thanks. Started all other radiators, but can you help me understand how to bleed boiler ? I have attached the pictures in my first post. I can hear a lot of noise near the boiler.
Old 12-25-18, 05:43 PM
G
Received 9 Votes on 9 Posts
When you try to bleed, temporarily jack up the system pressure to, say, 25psi.
