Replacing Legacy Controls on AS Arcoliner Boiler with Taco SR503-EXP-4
Old 02-23-19, 09:17 PM
atulc: On this thread post 26 I addressed short cycling paranoia.
atulc link https://www.energy.gov/sites/prod/fi...ing_losses.pdf. key word is “oversized” which leads to short cycling. It is very easy to increase cycle time by reducing firing rate/BTU. Just install a smaller $5 nozzle.
Aquastat/ODR delta-T also impacts cycle time. Delta-t of 5F has shorter run that 20F. I use 5F
atulc: link https://www.harscopk.com/uploads/201...979fb4126c.pdf is a mix of truths and falsehoods.
“note how few hours burner runs at the lowest temperatures” Which is often due to over firing.
Old 02-25-19, 05:48 PM
Link is a mix of truths and falsehoods.
Atulc link https://www.energy.gov/sites/prod/fi...ing_losses.pdf. “Boiler short cycling occurs when an oversized boiler quickly satisfies process or space heating demands, and then shuts down until heat is again required.”
Key word is “oversized” or overfired. It is very easy to reduce firing rate/BTU and increase cycle time by. Just install a smaller $5 nozzle.
My boiler at 0F outside design temp fires at 50% rated BTU, runs 8 hours (33%) per day. National average quote running times at 20% to 25% of time.
I optimized system performance by logging data and setup/adjusting for best efficiency. Have data showing 50 years of decreasing oil usage (from 1800 gallons per year down to under 600 gallons).
Much of reduction came from insulation, new windows, etc. but boiler/burner operation was also significant factor.
I found the pro's often have limited or poor understanding of heating systems. That is why I became a DIYer. Not only save thousands of dollars on fuel costs, do not pay for service contracts. Any heating issues are quickly addressed, no phone calls or waiting in cold house during snow storm.
  #43
Old 06-05-19, 09:24 AM
If your looking to purchase Intellidyne Economizers
Please email me at [email protected] or for technical data or product information go to www.intellidyne.green
Intellidyne LLC is the leading manufacturer of energy economizers for commercial and residential applications. Our exclusive line of heating, central air conditioning and commercial-refrigeration economizers is proven to reduce energy consumption between 10% and 30%. We guarantee a minimum of 10% savings.
Intellidyne offers energy economizer solutions for hydronic, steam and forced-air heating systems; a wide range of refrigeration units; package/rooftop units and PTACs.
Over the past 20 years, hundreds of thousands of Intellidyne Energy Economizers have been installed in government, commercial and residential buildings. Reducing energy consumption, lowering energy costs and even helping to reduce pollution – these are the pillars beneath Intellidyne’s strength.
