No lights on Argo AZ-6P zone controller
Old 03-14-19, 08:30 PM
Hi, per attached image, my zone control board isn't lighting up anymore. When I flip power on, I can hear a buzzing from the transformer but nothing is lighting up. I think I might have blown fuse when I accidentally crossed the red and white while messing with the thermostat connections. The problem is, there's no fuse on the control board that I can see. Do I have to pop the transformer out? No black reset switch or anything either.
Old 03-14-19, 09:23 PM
Welcome to the forums.
Thread moved to the boiler forum.
I highlighted the transformer but you say you can hear it humming.
I added a red circle to your picture. Check there for 24vAC.
If you have the 24v there.... you may have burned a foil on the back of the pc board.
If you don't have power there..... you'll need a new 24vAC 40va transformer.
The one in the link is a good deal.... Example of transformer
