Turn down aquastat in summer
Received 0 Votes
Hello, my boiler provides both baseboard hydronic heating and also domestic hot water.
The water coming from the hot taps are extremely scolding hot (180 degrees F). So we temper it with a valve that is partially open so that it mixes with cold water.
In the summertime, when hydronic heating is no longer needed, it seems very inefficient to heat the water up to 180, only to cool it back down with cold water.
Do you think there would be any problem if I lowered the aquastat setting a bit? What should I put the HI and LO settings at?
