Hot water baseboard heat loss calulator?
Old 05-03-19, 10:20 AM
I worked with a guy years ago installing gas hot water boilers, he would do the heat loss for sizing the boiler and baseboard and I would do the installing. I just built an in-law apartment and want to put in hot water heat put the guy I use to work with is no longer around. I found heat loss calculators online but they only calculate going by sq. footage of each room, as I recall there should be more than just figuring out the sq. footage, if I'm correct you also have to figure out the heat loss for windows being in each room too. Does anyone know of a good online heat loss calculator I can use to size my baseboard for each room?
