Attaching Wi-Fi Smart Thermostat to a RA832A relay
Old 09-09-19, 10:23 AM
A
Hello Friends,
I'm a home owner with limited know how... I recently purchased a home which has hot water baseboard heating system... I have total 3 zones and wiring includes 3 separate RA832A relays and a AQUASTAT L8148E relay.
Everything is working fine, however, the thermostat that I have at basement is very old... I would like to substitute the existing thermostat with a more modern Wi-Fi smart thermostat... Most such thermostats require a 'C' wire... Could you be able to help me understand how could I be able to get that accomplished.
I have attached the picture of the RA832A relay that is controlling the basement heating.
I thank you in advance.
Regards,
Anup
Old 09-09-19, 11:40 AM
Received 1,327 Votes on 1,226 Posts
Welcome to the forums.
#1) There is not enough 24vac current to run a wifi stat off that relay.
#2) There isn't a tap even available for a C wire.
That leaves you with using a separate 24v transformer to run the wifi stat.
It would be good to put the proper cable connectors in the relay for the wiring.
Old 09-09-19, 01:05 PM
A
Pete, thanks... I guess I either do that or just be happy to use a better battery powered TSTAT
