Zone 2 circulator pump not running
Old 11-10-19, 08:03 AM
My zone 2 circulator pump is not operating when there is a call for heat, the boiler will start up but the circulator will not turn on. The zone 1 circulator pump is operating normally. How can I test if it's a pump issue or some other possibility?
EDIT: It was the zone 1 circulator that wasn't actually working because there was no call for heat. I jumped R W for zone 1 and everything started up. If i jump the R W from zone 2 thermo stat to zone 1 would that work temporarily untill I can get a new thermostat?
Old 11-10-19, 12:20 PM
Received 3,892 Upvotes on 3,489 Posts
Welcome to the forums.
I see a correction notice of "worked out the issue". Does that mean all is ok now ?
Old 11-10-19, 01:41 PM
Yes it has worked out thank you!
