Honewell V8043F1036F1036 zone valve
Old 11-20-19, 12:09 PM
8
One of my 3 zone return lines to my oil boiler comes from below. In order to install the zone valve in the correct flow direction, it puts the wire connections on the bottom. Anyway to get these connections on top ?
Old 11-20-19, 02:33 PM
Received 35 Votes on 33 Posts
8,
Without pics it's impossible to see what you have. If you're installing this valve new it can also go on the supply line if that is easier.
Old 11-20-19, 07:54 PM
Received 595 Votes on 560 Posts
Pics are always helpful...... How-to-insert-pictures.
Old 11-20-19, 08:05 PM
8
The valve is already soldered in place. I took the motor off, and switched the cover over the valve area around to put the electrical contacts on top. However, when I put the valve in auto position, it does not close. (I have not wired the valve yet, just moving the manual lever ). I can feel the hot water moving through the valve.
Maybe, when wired it will operate?
or
Maybe there is a different way to do this? the photo should show the arrow pointing up, I dont know how to rotate the photos.
or, maybe I should just reassemble the valve as it was and just wire the contacts from the bottom ?
Old 11-20-19, 08:21 PM
8
attempt to rotate pic to proper orientation
Old 11-21-19, 03:42 PM
https://www.supplyhouse.com/Honeywel...e9ae6266a39993
I believe you have the motor on backwards. The manual lever should face the opposite direction of the arrow, most likely the way it was as the pic in fig 7 shows in the install instructions in the above sight.
Old 11-21-19, 08:11 PM
8
ok, I will try reversing it.
thanks !
