Boiler transformer/ relay help
Old 12-08-19, 09:10 AM
Hello all, have a Weil McLain boiler relay every so often clicks like crazy so would like to change it. Trying find the correct replacement. The relay is made by Honeywell, but honestly donít want to pay double price by going to a Weil McLain again. I attached the fan center pics and also schematic. The assembly number says R8285D 1000. The schematic day DPST. Any suggestions which is the aftermarket replacement.
Old 12-08-19, 09:27 AM
Attached pics are the boiler schematic also
Old 12-08-19, 09:41 AM
Received 22 Votes on 18 Posts
Check at SupplyHouse.com. Your original part number shows as discontinued but has this replacement:
https://www.supplyhouse.com/Honeywel...SABEgKEJPD_BwE
A Google search on your original part number comes up with this less expensive Honeywell part (different number) also at SupplyHouse.com:
You can call SupplyHouse.com to discuss the differences and whether the Honeywell part will work for you.
Old 12-08-19, 10:12 AM
Hi 2John thatís the part number I was thinking is the Honeywell replacement I wasnít going to buy a pen since some times there are generic versions available. So I believe the 5001 Honeywell is pretty much a direct replacement
Old 12-08-19, 06:37 PM
Received 482 Votes on 452 Posts
Any fan center can work in there but that isn't usually the cause of the relay clicking. A clicking can be caused by a thermostat issue. .
Old 12-09-19, 08:16 AM
Hi PJ you know funny you say that! My brother-in-law installed those fool Nest thermostats which I’ve heard mixed reviews I wonder if that is the smoking gun. There are 3 and in all installations they only have 2 wires and they also go back to the taco 3 zone control box.
What I have noticed on not noticed is he can energized/de-energize the thermostats from the app but I have not found the clicking happen during a specific one turning on or off. It also could be a combination on two or three being on. Not sure how we would isolate which one or combo it would be.
Old 12-09-19, 08:27 AM
I also pulled the relay to make sure the R8285D 5001 would work but still not sure if it will. I canít make the schematics up from Honeywell data sheet to the old relay. I attached the Honeywell schematic data sheet and the back of the relay. Any suggestions?? Or can you folks tell me for sure it will work.
Old 12-09-19, 03:41 PM
Received 10 Votes on 10 Posts
Relays are often generic.
Find a 24 VDC, 12 amp or more contacts, double pole relay with spade contacts.
Attach it with double stickum tape or whatever.
Here is one: https://www.alliedelec.com/product/o...B&gclsrc=aw.ds
Old 12-09-19, 04:48 PM
I guess my real question is will the R8285D5001 work in place of the existing R8285D1000. The old relay in the R8285D1000 is a R8222U they new one comes with a R8222B. I believe the old relay was a DPDT used as a DPST. The new one seems to be just a DPST. I just donít know how much rewriting I have to do to use the new one if any.
Old 12-09-19, 08:17 PM
The Hgy1243 relay in picture is DPDT with 3 contacts per pole.
When off/deenergized a poles contact 1 makes contact with 2 or 4 contacts 5
When energized contact 1 makes contact with 3 or 4 contacts 6
When replacing with SP, just use contacts 1 and 3 or 4 and 6 so when relay is energized they are connected.
Old 12-09-19, 08:51 PM
@ doug......
Are you sure it shouldn't be 24vAC ?
Very doubtful you have a relay problem.
Most Taco zone valve controllers will not run power stealing thermostats correctly.
Some, not all, Taco controllers have the ability for a three wire connection.
