Are both parts (A & B) needed on boiler?
Old 12-14-19, 09:45 AM
see pic
have 3 boilers, same oil pump, same burner
but they have different parts
if B is pressure switch, what is A?
if house pool have B, why does shop not have B?
and
could we just take B off house and pool?
thanks
Old 12-14-19, 03:36 PM
Received 21 Votes on 20 Posts
This is just a suggestion. Those valves did not come with the burner but were added on after so my suggestion would be to call your service man and find out why they were put on.
To answer your question the burner can be run without A. Can't tell what B is because of the angle of the pic but my guess would be that could be removed also.
If you google solenoid switch you can pull up info on their use on oil burners.
Hope this helps a little.
Old 12-14-19, 04:31 PM
Hi Thanks
Am talking to boiler tech but thought I would "smarten up" to act less dumb
B is a pressure switch
What is A?
Old 12-14-19, 05:39 PM
engrav
A is a solenoid valve.
Old 12-14-19, 10:07 PM
Received 53 Votes on 49 Posts
A is an oil delay solenoid valve. That burner prepurges the combustion chamber before igniting. It is most likely a factory installed OEM part.
Old 12-14-19, 10:12 PM
thanks
got it
but then the other question
we have 3 of these boilers
two have part A and one does not
two have part B and one does not
why not all 3 A and B?
Old 12-14-19, 10:26 PM
Some burners have prepurge and others don’t. Depends on the model and setup of the burner.
I’m not certain what the other part is other then it’s some type of pressure switch.
Old 12-14-19, 10:36 PM
thanks
maybe I have enough lingo now to talk to the boiler tech
ask him why 3 identical boilers and 3 identical burners and 3 identical pumps have different A and B setup
thanks again, over out
Old 12-16-19, 06:47 AM
Grady's Avatar
Received 13 Votes on 11 Posts
B is indeed a pressure switch. Switches of this type of often used to trigger a relay to turn on a remotely located fuel supply pump.
