New boiler question
Old 12-28-19, 03:52 PM
D
New boiler question
I have a 30 year old Slant Finn thatís on its last legs. Been pricing around boilers. Project ranges from 6k-12k. I just want a reliable boiler. A contractor priced me a Williamson for 5900 and a peerless for 7500. What are the differences in these two companies. Is one really better then the other?
Old 12-28-19, 03:58 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
I moved your thread to the boiler forum. Hang tight..... the boiler guys will be by.
Old 12-28-19, 06:11 PM
poorplmbr's Avatar
Received 1 Vote on 1 Post
We would need the specs on each to be able to tell you the difference. Did the contractor not explain the pros and cons of each one?
Old 12-29-19, 07:21 AM
Received 5 Votes on 5 Posts
Why do you say that your 30 year old boiler is on it's last leg? Is the boiler leaking or or not heating properly? Is this a steam or hot water unit? Boilers can last a lot longer than most people think. I have seen them last more than 100 years. As @poorplumber said more information is needed and a few pictures would help.
Old 12-29-19, 08:31 PM
D
Received 23 Votes on 22 Posts
When properly maintained, boilers do not have establish lifetime.
I have 70 year old Weil-McLain boiler that operates at 86% efficiency. Would replace it only if irreparable leaks develop.
Greedy contractors push for new boilers when old one just need proper maintenance.
lawrosa voted this post useful.
Old 12-30-19, 07:53 PM
D
thank you all for the replies. It is a hot water boiler not steam. I do yearly maintenance on it what other upkeep is needed besides if something failed?I have well water that is very hard. I do have a softener. There is rust coming out of some areas i was told
its a leak. I do have pictures but I Must be an idiot because I canít figure out how to put pictures on this thread from my phone.
Old 12-30-19, 10:02 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
The williamson is a weil mclain product.. The sections I believe are put together with elastomer sealing gaskets seals. The pearless is push nipple design..
My old boiler was 50 plus years old hydrotherm push nipples...
Your old slant fint was/is push nipples..
What do you want.?
10 years maybe 15 years seals? 30 plus years nipples?
Your choice..
But what boiler are they putting in? 7500 a lot for peerless..
Should be same install as williamson price..
https://www.supplyhouse.com/Peerless...Boiler-Nat-Gas..
@ 5500 they are making 2500 for one days work...
Old 12-30-19, 10:07 PM
lawrosa's Avatar
Super Moderator
Probably an 800 buck difference between boilers..
https://www.discountbandit.com/willi...ith-70000.html
Me I go push nipples hands down... but get price down for nipples
Old 12-31-19, 06:45 AM
D
The prices also include re piping the boiler room and a Taco 24v 2 zone valve what ever that does. It adds 1500 to Bill. Not just a cut and Swap. I have had 5 people out for estimates and they are all around 9-12k. So just Williamson boiler installed is 5900 and peerless is 7800. Those are prices without The Taco valve. Is that needed?
Old 12-31-19, 08:57 PM
D
Dcuozzo1 seems to have a thing for new boilers.
I have a thing for money. Knowing that money is in the bank for a rainy day does more for my ego than a new boiler.
My old boiler heats well, is economical on fuel, minimal maintenance cost, very reliable, runs 8 hours a day at zero F. It may not be a shiny new show piece but no one sees it. And I spend a lot less on heating than my neighbors.
Old 12-31-19, 09:16 PM
We make recommendations to members and then move on.
Old 12-31-19, 09:30 PM
lawrosa's Avatar
Super Moderator
its a leak. I do have pictures but I Must be an idiot because I can’t figure out how to put pictures on this thread from my phone.
Rust? Possibly you have a condensation issue.
Taco zone controller just makes the install easier. no its not needed.
But they are about 120 bucks..
https://www.supplyhouse.com/Taco-ZVC...-with-Priority
and zone valves are also cheap.. so not sure how he comes up with 1500 bucks.
https://www.supplyhouse.com/Honeywel...eads-1718000-p
Maybe 400 in parts..
Old 01-06-20, 03:40 AM
D
Hear is a picture of the boiler. See the build up on the right side. I have been told by several people that is not good and nobody wants to mess with it and open a can of worms.
Old 01-06-20, 03:43 AM
D
Here is the picture did not attach
