15-58 fc pump failure
Old 01-05-20, 06:06 AM
W
I have a 15-58 fc pump. It got hot and stopped circulating water. I manually increased the water pressure and the pump began working it shortly failed again. I replaced with a new pump after about 2 weeks the same problem occurred., the pump is hot to touch and not circulating water.
Old 01-05-20, 07:26 AM
Grady's Avatar
Received 37 Votes on 35 Posts
How much pressure is on the system? Is it possible there is air in the system preventing the pump from getting water? Pictures might help.
How to insert pictures.
Old 01-05-20, 07:34 AM
P
Received 26 Votes on 22 Posts
Not sure if this could cause it but maybe a zone valve downstream isnt opening? I had one of my taco 3 wire zone valves' motors rotate slightly and disengage from the valve in the pipe. So on call for heat, valve motor head would energize, end switch would close and fire boiler/turn on circ but motor was detached and never opened the valve. I can't imagine my circulator was happy; just glad I was home and caught it. Not sure if this is a likely scenario for your symptoms; just a thought.
