Only half of my house is heating up
My house is split into two sections. An uostairs apartment area and a second level with a basement. The second level and basement heat work fine but the upstairs heating isnt working at all. Could it be a pressure issue. I will send photos, to anyone who can help. Thank you.
Welcome to the forums.
You posted in the furnace forum. Is this a furnace with hot air or a boiler with hot water ?
You can post pictures here...... How-to-insert-pictures.
A moderator will do that.
Where are you zone valves? You need to check the zone valve for the area that’s not working. If it’s not open you’ll need to check voltage.
What is the boiler pressure?
Yes you have no water in the boiler... we need more pics of boiler if we are to help.. well lit and take several of all controls.. we need to add water..
Why did you remove water!!!!
If you are not sure what your doing its best to call a pro..
You can dry fire and when cold water hits the cast iron...KABOOM!!!!!!!!
Please explain how and why you removed the water.
Is the boiler still running?
If so please shut it down and use space heaters. A boiler running with low or no water is extremely dangerous. Putting water into that empty boiler when hot is even more dangerous. Either can cause an explosion that can kill you and level your home.
