weil mcclain hot water boiler - not working
Old 01-22-20, 10:29 AM
Y
getting error message in RED
LOW WATER CUTOFF OPEN
STATUS: LOCKOUT
heater has stopped working and need help / guidance pleae
Old 01-22-20, 12:40 PM
T
Received 31 Upvotes on 25 Posts
It would appear you've run low on water. Is this a steam system or hot water radiators? More information about your system including pictures will help.
Old 01-23-20, 05:52 AM
Y
very many thanks
this is a hot water boiler ( two zone - radiators and base boards ) - not steam
model is: wm 97+ ( by weil mcclain )
why it has triggered ?
how to check water level ?
how to cure ??
best wishes
Old 01-23-20, 06:38 AM
T
There should be a temperature and water pressure gauge on the boiler. The pressure should be around 12 - 15 PSI cold. Take a few pictures of the system and post them so we can guide you on how to put water back in it. Take a few from a bit away so we can see everything.
Old 01-23-20, 08:25 AM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Here is a link to putting pictures in your post. Putting pictures in your post.
Old 01-23-20, 10:01 AM
Y
see pictures
pressure gage and other installation
i can give you some more if you need it
this is WM 97+ HOT WATER BOILER ( 3 zones - one radiators, second one is base boards and third one is hot water for shower
Last edited by yvs6b; 01-23-20 at 10:08 AM. Reason: pictures are not loading - may be bigger then permitted
