Need Recommendation: Stat/Sensor for hydroair return line
I have two hydroair units in the house. The blower is controlled by a Taco HAFC201-4. I want to attached a sensor/probe/aquastat (whatever the correct term is) to the return line after the exchanger to trigger when the fan will turn on (the HAFC201-4 already has a TT connection for this). So the sensor should be normal but close when a set temperature or above it is achieved. Ideally the set temp is variable and the thing is cheap. lol. Does a cheap sensor/swtich like this exist?
Thanks.
Thanks.
ive found something like the Honeywell L4006B. This makes the circuit on temperature rise but does it work with a 24V TT switch? Its designed for 120/240V circulators? Its also a bit pricier than I want to spend.
Ranco makes some pretty good and inexpensive temperature controls that'll probably work for your intended purpose.
I'm not sure this one is exactly what you need, but here's one example: RANCO ETC 120 Series
ebay has temperature controllers starting at $2.00
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
I agree with Doug 100%. Go with an inexpensive digital controller. You can get a basic board for a couple of bucks or in a nice case for $10-15.
Most will run on 12vdc and have a form C relay.... (normally open and normally closed)
Will connect directly to TT connections.
Relay type temperature controllers
