Slant Fin Gas fired steam boiler
Slant Fin gas fired steam boiler, Model # GXHA-120 EDPZ is not igniting. Pilot is not on. It uses intermittent spark ignition. Please help. I have no heat.
Welcome to the forums.
There could be several things causing a problem.
1) problems with vent damper. Not opening fully.
2) low on water if you have a low water monitor.
3) open limit switch.
4) thermostat problem
Are you familiar with troubleshooting ? If not..... call for service. If you don't have a tech.... call your gas provider. They have some good techs and their prices are usually very reasonable.
Otherwise you can follow the wiring diagram printed on the service door or the diagram in the manual link below. You'd need a meter and know how to use it.
Galaxy/Slant Fin manual (pdf)
