Adding Taco ZVC404
Old 02-05-23, 08:25 AM
W
Adding Taco ZVC404
WM GTO-4 boiler with L7224U a'stat.
3 zones (Honeywell V8043's) + IDHW
All seems to work fine...but since I can never leave well enough alone, I'm thinking about adding a ZVC404...essentially for 2 reasons:
1. Having the IDHW on 'priority' seems like a groovy idea
2. The wiring from the 3 ZV's goes into an insane rat's nest that drives my OCD absolutely nuts
(and 3... I really like blinky flashy LEDs)
Anyway - the wiring / installation looks pretty straight-forward - but I do have one quick question:
- On the ZVC404...does the ISOLATED END SWITCH go to the TT terminals on the L7224?
The diagram says "To boiler aquastat relay TT"...which I think is the TT terminals on the L7224...but I wanted to ask, just to be sure.
Thanx in advance! Wally
Old 02-05-23, 08:35 AM
W
Mods - just realized I may have put this in the wrong forum (didn't see the 'boiler' section.
Please feel free to relocate it if necessary.
Thanx!!
Old 02-05-23, 10:53 AM
Received 3,420 Upvotes on 3,066 Posts
Thread moved.
It's all about the flashy lights.
To the boiler TT takes the place of terminals 2 and 3 on the Taco valves.
Old 02-05-23, 11:17 AM
W
Hey PJ!! Long time, no....uhhhh...whatever.
Not sure I follow...? Taco valves? My ZV's are Honeywell.
What am I missing?
Wally
Old 02-05-23, 01:56 PM
Same thing.... uses the red wires from the Honeywell valves.
The red wires go to the controller along with the yellow wires.
The TT output replaces the red wires.
Old 02-06-23, 06:41 AM
W
Thanx PJ! The thermostats and ZV's are easy peasy.
But my question is specifically regarding the ISOLATED END SWITCH (basically the main end switch on the ZVC404). Take a peek at this: https://s3.amazonaws.com/s3.supplyho...structions.pdf
...along the top - left of the thermostat terminals.
Pretty sure it goes to the TT term on the aquastat (so the boiler can 'do it's thang.'
Thanx!
Wally
Old 02-06-23, 08:12 AM
rbeck's Avatar
Received 61 Upvotes on 51 Posts
You are correct!
Old 02-06-23, 08:38 AM
W
Thanx rbeck!! One of those "I-know-the-answer-but-better-ask-since-I-ain't-a Pro" things.
Even tho I'm not a Pro - I'm pretty handy, and comfortable doing this...not much to it.
Thanx again!
Wally
