For the past few months our boiler has been kicking off/on/off (almost 'stuttering' or misfiring I would say), near the time when it's about to kick off. In other words, it (I think) only does this minutes/moments before it actually shuts off (either due to the house reaching temp and the thermostat told it to turn off, or the hot water heater reached temp and told it to turn off). It (again, I think) doesn't happen when it first turns on or in the middle of running (i.e. if it turned on, and stayed on for an hour b/c the house was really cold, it would only happen right near the end of that hour).
I also noticed that the bucket is filling up a bit from the relief valve (probably an inch or so of water, whereas normally it's dry). I believe that means the expansion tank is either bad or needs to be otherwise needs to be fixed, but I don't know if this could at all relate to the boiler going off/on/off.
I'm going to have a pro come and look at/service it, but before doing so wanted to run it by the experts here, to see if you can advise as to what the issue might be/what it might cause to fix. I've had issues in the past with a (different) company telling me I needed to replace so many parts, so I want to have some idea of what the issue likely is in case this company tells me I need to replace thousands of dollars worth of parts...
The person that does my annual tune-up (whom I trust) is not available to come service it right now.
Hi. I'm not sure I entirely understand your question, but I guess the answer is no. The boiler is (as far as I can tell) working perfectly fine at all times (including for 1-2 hours in a row when the heat kicks on in the morning). The issue only occurs right before it's about to turn off (it seems to know that it's about to turn off, and then his stuttering occurs before actually turning off for a while, until heat is called for again). Once heat is called for again, it works perfectly fine until it's time to turn off again when it then stutters again. It doesn't always do this, but it's been happening more and more.
I’m not a boiler guy but I do my own maintenance. As far as I know boiler shutdown sloppiness like that can be caused simply by lack of service. The nozzle and filters need to be changed periodically. I do it once a year and I don’t think you can go too many years without doing it.
Also, I think if air is getting into the oil line that can cause sloppy shutdown. Not sure how common that is though.
If you haven’t had service for a long time maybe that’s the problem and that could also explain why your pressure is going up (losing water at relief valve). The pressure tank may need air if you haven’t had service for a long time.
I think you can check the pressure tank yourself. I thought there used to be a sticky on this forum that told you how to check/add pressure to the tank, but I don’t see the sticky now. You can probably google and find the instructions. I don’t have a bladder tank so I’ve never had to do that procedure.
Your 2017 post photo shows a boiler with a control on the front of the boiler. The control turns the boiler on or off based on state of control signals from the house thermostat or the aquastat monitoring the water in the boiler used for the circulating hot water heating system. There could be a third control signal from another aquastat if that is a domestic hot water tank near the boiler and uses the boiler to heat its water . Since any of the 2/3 control signals turning on/off rapidly could cause the condition you mention, my approach would be to take steps to only have one control signal controlling the boiler through a burner on to off cycle. One of the 2/3 signals should cause this condition. The source should be repaired. Since this is usually beyond a DIY effort, I would contact a reputable HVAC company, not the ones you used in 2017.
You have multiple zones so it is possible that when one zone shuts off another one is starting or multiple zones satisfied at almost the same time but I wouldn't think this coincidence happens every time.
Your heat is controlled by thermostats and your hot water is controlled by an aquastat on the tank so although they do the same job they are different so I believe they can be eliminated. The common denominator is the boiler aquastat control.
What you can try is to turn everything down so nothing calls and then turn one up at a time until satisfied and see what happens.
I have seen your problem with zone valves but not circulators.
Thanks. I should add/clarify (as I didn't really do so above), that this happens both when the heat is about to kick off, but also when the heat is not in use, and the boiler runs to heat the hot water tank.
It's definitely not related to 1 heat zone going off when another goes on, as this is a brand new issue that never used to happen.
Also, as just noted, it happens both in relation to the heat and the hot water heater, so again, I don't think it's related to a specific zone either.
If they are Taco 555 zone valve powerheads, little boxes le green or gold pyramid devices on the valves on pipes, they will sometimes do this due to the heat motor going bad.
I had a (hopefully) more reputable company come out, and of course we couldn't duplicate the issue when he was here. He said to call again/try to take video if/when it happens again. He didn't mention anything about the 2/3 control signals nor did I remember to mention it.
Separately, he did provide an estimate for the expansion tank (and some other related items, I think). Does this seem reasonable ($1,538.67 including tax):
What brought up the replacement of all these parts. If your relief valve only drips after the boiler is reaching temp then I would check the expansion tank.
The relief valve is doing its job if it leaks at 30 psi and then stops after pressure drops. If your boiler maintains a constant pressure when off and does not climb your auto feed/ backflo are fine.
It sounds like you just need to check or replace your expansion tank and to do that you can isolate your system from your boiler. Open up your boiler relief valve for a few seconds to drain the water to a point below the tank so there would be no or very little refilling and most likely no bleeding so you can eliminate the cost of draining & refilling the system. When the tank is replaced and the cold water valve is turned back on the feed valve will add the little water needed by itself and most likely will be fine.
In my opinion for the prices quoted you are being taken advantage of. The way your system is set up even if everything they listed was needed it could be completed in way less than 2 hrs. time.
I would get a couple of quotes or just have them change the expansion tank and add a shutoff between the tank and the boiler for future tank maintenance. All these parts and the leak have nothing to do with the on/off situation.
Thank you. I'll definitely get a second opinion first, and/or just get another company to do an annual tune up and see if they say anything to me.
The only reason he did the estimate is I pointed out the water in the bucket. I don't know if he then quickly checked anything or just started naming parts that would need to be replaced along with the tank and/or in conjunction with trying to solve the on/off issue.
What he did was price everything that could possibly be connected with the drip and hope for the best that you would say GO AHEAD and he would have had a great payday for a couple hrs. work with traveling.
They should be done every year. The nozzle, filter, pump screen (if any) brushing if needed and efficiency test done, This will not address the drip but most likely just the replacing or recharging the tank will.
Hi,
Great Forums and Folks.
Hope that this is the right/best Forum for this.
If not, please let me know.
Live in a typical Colonial in Mass.
Have a 40 year old Hydro Therm forced hot water (Gas) system for heat.
Time for a new one.
Shame, as I love the fact that it has the Thermopile ignition system, which
apparently is no longer offered by anyone. True ?
Regarding Brands:
Who has the best reputation these days for a forced hot water gas fired heating system ?
Who to stay away from ? (probably even more important)
For a 2 story typical New England Colonial, what, very approx. would be the
expected price range for the unit and installation ?
What kind of Warr. is generally offered these days ? Cost ?
Thanks, appreciate any thoughts and opinions,
BobRead More
(The title has a typo, supposed to be GFCI but can't edit the title)
I noticed yesterday there was no hot water, which led me to notice there was no electricity to the heater (a several years old Navien combi boiler). It's ultimately connected to a GFCI outlet which had tripped.
However after resetting the outlet the boiler turns on but then a short time later (sometimes as short as 20 seconds, sometimes not for a few minutes) it trips again.
There's no visible water leaks anywhere, and the boiler is only a few years old so it's not like there will be some old worn out wires etc.
What might be the cause of why its continually tripping?
The zone valve control box is also connected to the same outlet, therefore could it perhaps be that that is causing the trip rather than the boiler?
I'm not going to attempt to fix this myself, I'm going to call a plumber/electrician to look at it, but I'm curious to get some background info and know what the causes might be before doing so.
Also any suggestions on whom is the best sort of contractor to call to take a look at it? If it's the boiler itself, then as its a Navien maybe I should call a contractor listed on the Navien website contractor list? Or an electrician to first determine if there's some ground fault? Or a good boiler plumber should have equally good knowledge of the plumbing/heaters side and the electical side of things?
TIARead More
