armstrong pump - relays on wall- valves open and close
Have older system 90 s
has armstrong pumps that are connected to relay switch and zones have electronic open and close valves
So i installed new pump ( 3 total )
Problem new pump not running
fuse is oky
switch is oky
Only 1 pump is working
new pump not turn on
fuse is oky
switch is oky
Welcome to the forums.
I'm lost..... you installed three pumps for ......... three zones ?
If yes..... why are you using valves.
Typically it's one pump and a valve for each zone.
When the zone valve opens... the one pump runs.
If you have three zones with three pumps.... you don't use zone valves.
You would check/anti flo valves.
We need to know more about what you have.
Pictures can be a big help..... How to insert pictures.
