How to drain this water heater
Old 04-12-24, 03:08 PM
How do you open this? I nearly took the pvc part off and it was barely any water drained
Old 04-12-24, 03:36 PM
G
Received 28 Upvotes on 27 Posts
Is the water heater already junk and you are just wanting to drain it and replace it?
Old 04-12-24, 03:56 PM
T
Received 111 Upvotes on 99 Posts
Your picture is the drain valve. Turn off the water in and open a faucet. Just turn the valve up to 1/2 turn counter-clockwise. Close it by turning clockwise. If necessary, use a wrench or pliers to keep the stem from turning.
Old 04-12-24, 04:27 PM
Received 4,049 Upvotes on 3,632 Posts
Even if the valve was opening correctly.... it's tough to drain a tank.
If I'm replacing a tank... I cut the supply lines.
Cap one and connect my air compressor to the other.
It doesn't take much pressure to force the water out.
Old 04-12-24, 04:58 PM
Thanks guys. Got it. I didn't even open any faucets to relieve pressure, apparently I have no idea how water and air behave, but it's going slowly now
