sand/cement ratio
sand/cement ratio
Hello, I'm going to be laying Belguim block down my driveway on a concrete base and tapped to level with a mallet. I need to know how much sand to use in the mix??? Is 2 to 1 concrete to sand good or should it be even??? I will use the same mix for the joints. I also need to shore up my patio a little bit, can I use the same mix there??? Thanks in advance for your help!!! Eric
This might help from ebricksolutions.com
http://ebricksolutions.com
Unit Masonry C270 includes the following mortars: Prepared Masonry Cements (ASTM C91) Type N, S, or M
One 70-80 lb. bag masonry cement (ASTM C91, Type 1) plus 3 cu. ft. sand (ASTM C144) Portland Cement - Lime Mortars Type N (750 psi)
One 94 lb. bag portland cement (ASTM C150), One 50 lb. bag hydrated lime (ASTM C207), plus six cubic feet sand (ASTM C144) Type S (1800 psi)
One 94 lb. bag portland cement (ASTM C150), One 50 lb. bag hydrated lime (ASTM C207), plus nine cubic feet sand (ASTM C144), OR
One 94 lb. bag portland cement (ASTM C150), Two 70 lb. bags masonry cement type 1 (ASTM C91) plus nine cubic feet sand (ASTM C144). Type M (2,500 psi)
Two 94 lb. bag portland cement (ASTM C150), 25 lb. hydrated lime (ASTM C207), plus six cubic feet sand (ASTM C144), OR
One 94 lb. bag portland cement (ASTM C150), One 70 lb. bags masonry cement type 1 (ASTM C91) plus six cubic feet sand (ASTM C144). Type O (350 psi)
One 94 lb. bag portland cement (ASTM C150), Two 50 lb. bags hydrated lime (ASTM C207), plus nine cubic feet sand (ASTM C144)
Here's somemore stuff to check out, I have included
source:
This Technical Notes is a continuation of Technical Notes 11 Series on "Guide Specifications for Brick Masonry" and contains the requirements for mortar and grout for brick masonry. This Technical Notes is appropriate for both empirically designed and rationally designed brick masonry.
The guide specification in this Technical Notes is in accordance with the Construction Specifications Institute's Masterformat and is based on the requirements of BIA M1 Standard Specification for Portland Cement-Lime Mortar for Brick Masonry contained in Technical Notes 8A and ASTM C 270 Mortar for Unit Masonry. Mortar conforming to the requirements of BIA M1 will meet all of the requirements of portland cement-lime mortars of ASTM C 270. A complete discussion of mortar properties is contained in Technical Notes 8.
http://www.bia.org/BIA/technotes/t11e.htm
The selection of mortar for brick masonry has many consequences. Choosing the right mortar can lead to good performance and a durable masonry wall. Improper selection can lead to leaky walls or deteriorating mortar. Mortar selection is more than picking a mortar type. All aspects of a project including design, material selection and workmanship must be considered to lead to the choice of particular mortar materials and type.
This Technical Notes will provide the designer with a rationale for selecting the
http://www.bia.org/BIA/technotes/t8b.htm
source:
Something else to consider
Health effects
Cement can cause ill health mainly by:
skin contact: contact with wet cement can cause both burns and dermatitis:
http://www.hse.gov.uk/pubns/cis26.htm#2
Cement is one of the most widely used construction materials. Anyone who uses cement (or mixtures containing it eg mortar and concrete) should be aware that it may be a hazard to health and that safe working practices must be used to minimise the risk. This sheet advises on how to use cement safely.
http://www.hse.gov.uk/pubns/cis26.htm#4
Health effects
Okay, here is an easy way to determine the concrete mix ratio,
1/2 bag of 94 lb portland common cement, (common cement has no lime added)
10 shovels of sand
12 shovels of gravel
mix in wheel barrow or 1/3 sack mixer, adding water until a shovel can easily be drawn through the mix.
for the joints between the block you need to use mortar, here is the mix,
1/2 sack plastic cement, (common cement with lime added)
12 shovels of sand
mix with water to a firm consistancy
There you go, it's not rocket science!
Have fun, Nucman
10 shovels of sand
12 shovels of sand
Have fun, Nucman
