covering a foundation with thin brick
I have a 100+ year old home with a rough concrete block foundation that is not attractive. I saw one that was the same but covered in a real brick that appeared to be thin (Z-Brick?) Is this a job I could do and where would I get directions? thanks, Ray
Hi,
You can consider brick veneer, with nominal of 3" thick brick. It will be attached to your concrete wall with ties (air space not less than 1"). You'll need one tie each 2.5 sq. feet.
Of course, first you'll need to confirm the foundation conditions for this work
Hope this helps!
Hope this helps!
