leaking basement walls
Hey fellas, I am over here from "Basements" :-) I have ( I believe) water entering my basement through a whole where a pipe exits the house. This leak seems to be caused by water in the cores of the blocks above the poured foundation. In addition to doing the outside fix, I want to shore up the inside and I have been advised to use hydraulic cement. In fact, though, I am really just building up a block between the center of the cores where I believe I have water and the inside wall. I thought hydraulic cement was best for filling cracks and such. Anyways, some advice here? If I build up enough of a cement barrier, might that solve my problem? Is there a better solution than cement?
All opinions are appreciated and solicited.
Ken
Ken
leaking basement
Hi,
The advice you received at Basements is OK.
But IMHO, you need first to be sure where the water comes from. This is the main point. I mean, it is leaking by the hole, but it is coming from...? Drainage?
Depending of this, the liquid pressure may be different and the solution may be different.
Good luck,
Good luck,
