Concrete Mix
Old 07-07-03, 08:38 AM
D
Concrete Mix
I'm ready to pour about 30' of footing underneath my porch. Does anyone know of a good cconcrete recipe? How much cement, gravel, water. Is there anything else that I'm missing? There won't be much weight load and no freeze/thawing to worry about. I priced out bringing a truck in but for the small amount I need, it's cost prohibitive so it's rent a mixer and bring in bags of everything for the job. Any help will be appreciated.
Old 07-07-03, 12:10 PM
Brckman29
I would use pre-mix bags instead of raw materials. A lot easier to mix with less mess. Most pre-mix is a strong enough mix, but if you want you could add a little portland to the mix
Good Luck,
