masonry wall
Old 07-21-03, 02:48 PM
tohfan
Question masonry wall
I just had an attached carport turned into a garage.I took stone off an existing wall and want to use it on the facade.There is going to be 2 feet on each side of the overhead door and just a little over a foot above the door.Would this be a doable project for an amateur,or should I just go ahead and hire a mason?
Old 07-21-03, 03:03 PM
pmgca
Hi,
Can you tell us what kind and size of stone are you trying to use?
Regards
Old 07-22-03, 06:36 AM
tohfan
It is a bedford type stone.All stone is the same height but in lengths varying from 8"to 48".
Old 07-22-03, 08:52 AM
pmgca
Hi,
Sorry I didn't explain right, my question was about thickness. Also, is it real stone or some kind of "cultured stone"?
Best,
Old 07-22-03, 11:31 AM
tohfan
It's real stone,about 3"thick.
Old 07-22-03, 11:41 AM
pmgca
Hi,
then the best you can do is call a mason, because these stones are not veneer, and can't nbe installed as bricks,
Good luck!
Old 07-22-03, 02:09 PM
tohfan
On the wall I took these off of ( which was originally the end wall of the house before the carport was added)they were laid just like brick.This stone is just like brick only in various lengths.
Old 07-22-03, 06:11 PM
pmgca
Hi,
what I meant is that you can't put them easily as bricks, stone installing requires some practice
Good luck,
