Concrete slab
Old 08-19-03, 07:00 AM
fhodsoll
Concrete slab
I am going to build a concrete slab off the back of our house to be a floor under a new deck (storage and such). I want to make sure I build correctly and need to create pitch for water run off. What resources can I use to make sure I am doing the right thing
Old 08-19-03, 04:34 PM
C
When you get your permit, there will likely be information about the proper grade for drainage. Generally, you slope 1/4" per foot away from the house.
This article should address your question in more detail.
http://www.hgtv.com/hgtv/rm_home_ext...384073,00.html
Hope this helps.
