siding to brick
Old 11-03-03, 09:57 PM
P
siding to brick
What would I use to make a foundation to support the brick I intend to replace my aluminum siding with. The existing foundation does not come out far enough to place the brick onto?
Old 11-04-03, 08:35 AM
C
Ordinarily, the brick ledge is built into the foundation when it is poured. You could probably have the foundation excavated and a brick ledge added to the existing foundation.
It seems like a more achievable goal to use cultured brick to apply as siding. It is much lighter than brick and is applied with adhesive. It would not require a brick ledge to support the ponderous weight of brick.
Here is a link to installing cultured brick.
http://www.vannesstone.com/Cultured%...les/BRINST.pdf
Hope this helps.
