Glass Block Wall
Old 11-11-03, 06:49 AM
fhodsoll
Glass Block Wall
Hi:
I would like to build a galss block wall as part of remodelling a bathroom. This wall will provide on wall of a shower stall and separate this shower and the framed in tub. I would liek a how to guide. See word document attached.
Old 11-11-03, 03:28 PM
C
Here is some info from a manufacturer.
http://www.pittsburghcorning.com/hom...stallinstr.asp
Hope this helps.
Old 11-12-03, 05:14 AM
scooter100
Thumbs up go for it
Just a note Francis to let you know that a lot of the advice you will find will tell you that you need to be an experrienced installer. I am not at all experienced with any sort of masonry, but I was able to build glass block both freestanding and embedded in a wall. It is not easy, but IFICDI,SCY (if I can do it, so can you)Good luck, and share a photo of your completed project. I like to see others design ideas. scooter
Old 11-14-03, 12:27 PM
fhodsoll
Concrete pad
Thanks to all.
