cracks in concrete driveway
I have some very small cracks in my 3 year old driveway. I tried the patch stuff from Lowes, but after a small time you can see the cracks on the surface. The cracks a very small, if they were bigger it would probably be easier to fill. What can I put into these very small cracks to fill them and hide them.
Thanks
Thanks
Purhaps go to
www.decorative-concrete.net
and ask in the forum. They have lots of solutions and some flexible stuff you can pour all over your driveway.
You definately don't want to use a caulk--unless you want to be doing this again in a year. Definately look for a flexible yet permanent solution. If your driveway is asphalt, know that nothing will permanently bond to it. If it is concrete, you'll be able to search concrete repair and find a permanent solution. Stay away from epoxy fillers, as they will crack over time. Good luck in your search.
Stacy
Stacy
