vapor barrier
Old 02-25-04, 03:01 PM
Housemarried's Avatar
Married only to a house!
vapor barrier
I am in the process of turning my carport into a garage. I have cut the existing slab to pour a thicker footing for the walls. My plans approved by the city does not call for a vapor barrier between the earth and poured footing. Do I need one and if so what do I use? I am in South Florida so there isn't a problem with the ground freezing.
Old 02-26-04, 08:09 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
You don't need a vapor barrier under this garage footing.
Good luck!
Mike
