drainage around foundation
Old 03-10-04, 10:59 AM
btrflyndskies
My house is on a concrete slab and has brick veneer walls. I have had some water come into the house in one corner. There is a steep hill outside that drains water away, but also toward the house in some areas. My problem is that this one interior corner that gets wet is about 4 foot underground.
I have dug a 4 foot deep trench along the wall and have exposed the concrete footer. I plan to paint the bricks and footer with a concrete sealant and put plastic over that plus a french drain.
My question is this: Where should I put the french drain and exactly how do I install it? Do the holes go up or down? Do I need gravel around it? Any advice appreciated.
Old 03-10-04, 07:31 PM
C
Old 03-10-04, 10:30 PM
millertime
drain goes at the level of the footer. holes down, 3/4" crushed gravel surrounding.
