concrete slab removal
Old 03-22-04, 07:46 PM
gregoryk
I am going to be removing a 6ft x 6ft concrete slab, (approx) 6 inches thick. It is graded incorrectly towards the house and pools. It is right up against the foundation of the house on 2 sides. Prior to jackhammering should I try to cut along the edge with a masonry blade on a circular saw, or will the jackhammering do the trick? Thanks.
Old 03-22-04, 08:28 PM
chingao81375's Avatar
construction hand
If you are talking about the edge against the foundation chances are that you wont need a saw. If it looks like its connected together then you will.
