Repair cut by saw in concrete
Old 05-10-04, 08:54 AM
bksrj58
Hi,
I had my concrete foundation cut to put in a window. I have a couple 1/4 inch by 10 inch overcut from the saw blade.
It will take a long time to fix this with hydraulic cement.
Can I fix by putting shims in first (pressure treated, electrical outlet box covers) and then putting the hydraulic cement?
Does anybody have any ideas?
Thanks
Old 05-11-04, 08:36 AM
C
You may be able to use a concrete repair product in a tube such as at this site to repair the cuts.
http://www.quikrete.com/diy/RepairingConcrete.html
Hope this helps.
Old 05-14-04, 05:49 AM
bksrj58
Thanks
Do you think I should put metal shims in to add strength?
I called Quikrete and the the help desk said to use a sand mix I would think a sand mix would become brittle over time and crack. The overcut is pretty deep.
